I have two mpg files i want to add to a vcd and use a menu.
I had some problems with NERO though...the disc just wouldnt
run.. so i tried NTI Cd Maker and it does work fine...
However, i have a really annoying problem now and i cant suss
out why its doing it. Everytime i use a background image it
always displays it in a REALLY ugly format. Low res would
describe it part of the way but basically the whole pics messed
up. Writing is not legible and colours etc just look messy![]()
Is this a stand-alone player prob (using a toshiba drive for vcd
because my sony s300 doesnt like cdr) or am i doing something
wrong?
Is there anyone out there that has used hi-res pics on NTI?
Also, does the picture have to be a certain size/colour depth?
I have tried reducing the picture but didnt make that much difference
Many thanks in advance
Try VCD easy for making svcds
It has all the options, including menus ( mpeg stills)
For PAL small images ( 480*576) the best source is 675*506
For PAl large images (704*576) the best source is 676*506
For NTSC small images (480*480) the best source is 563*422
For NTSC large images (704*480) the best source is 564*422
watch out for using the large images cause sometimes they dont fit on the TV ( or my standalone doesn't accept them
Thanks very much indeed
I'll try it and see if i have any joy!
how do you add image as background for video?
By madaks in forum Video ConversionReplies: 1Last Post: 20th Apr 2011, 23:48 -
Question on DAR and best image size for a pal movie menu background
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2011, 10:42 -
Dvdstyler error changing background image
By EAGLEEYE in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2010, 22:52 -
How to remove a shadow from the white background in the still image?
By coody in forum EditingReplies: 1Last Post: 15th Aug 2009, 23:38 -
DVD Menu Image Buttons With Video Background
By sk8_aholic in forum Authoring (DVD)Replies: 3Last Post: 19th Nov 2008, 23:01
