Anyone throw some light onto why when i have dma enabled for my dvd drive and i try to start up smartripper it throws up a windows protection fault and I have to reboot?.
If i turn dma off smartripper works but only at the max of 1.3x, which means takes bout an hour to ripp a film. Also cant watch dvds with dma turned on.
Athlon 1.2,Abit KT7A,256k ram,Nvidia GF4 Ti 4200,Standard pci sound blaster,Pioneer A05 DVD burner
BUMP^^^^^^^
Athlon 1.2,Abit KT7A,256k ram,Nvidia GF4 Ti 4200,Standard pci sound blaster,Pioneer A05 DVD burner -
I suspect it might be the drive, firmware, software driver, OS, motherboard, motherboard settings, jumpers, a power surge, a brownout, IDE cables, or a computer virus.
Really, it's hard to say. I do know that on Windows 98, it even pops up with a warning sometimes if you try to enable DMA on a device, saying if you have problems with it, turn it off.
I guess there muct be some incompatable drives out there. Microsoft must have had a reason to put that on there... better to notify than to actually fix a problem, I guess
<font size=-1>[ This Message was edited by: homerpez on 2001-08-27 08:43:20 ]</font>
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
