The Burning of the VCD on the Computer worked fine, but when I but the VCD in My DVD-Player I get the Message "Disc Error". Here my Configuration:
Encoding Software: TMPEnc (I used the Standard-Configuration for PAL-Files)
CD-Writer: HP CD-Writer Plus
Used Software: VCDEasy
DVD-Player: Toshiba SD-120E
Used CDs: ACER 650 MB 4x CDRW, SONY 1x - 24x Compatible CD-R 650MB
I burned Adio-CDs with the same kind of CDs. And they work fine on my DVD-Player.
It would be really great if someone could help me
Ummmm, looking at the compatibility chart, it appears that this Toshiba doesn't play CD-Rs or CD-RWs. I guess that's that.
Have you checked it's VCD compatible?
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=1430&Search=Search&#comments
Rob -
Wait, I completely glossed over the part "plays audio CDs". Well, if that's the case, I'll tell you what I suspect. A problem with the authoring OR a problem with the burning. Not necessarily a problem, but whatever's causing the disc not to play may very well be due to something during these stages.
For authoring, you're using VCDEasy. That's good. I wouldn't recommend anything else. So maybe we can rule that out. Are you burning with VCDEasy? Try CDRWIN. Try Nero. See if they do the same thing. Avoid Easy CD Creator. -
I now tried the following other programs for burning:
CD-Maker, Blindwriter, Nero V5
The Player should be able to play VCDs.
Menu doesnt work in uploaded video
By lloydswylie in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2010, 17:22 -
USB AVCHD for ps3 doesnt work
By caner12 in forum Video ConversionReplies: 2Last Post: 10th Aug 2009, 16:28 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 7th Mar 2009, 00:46 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 10:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 11:21
