This one has got me confused.
I've created a few cue/bin samples from using DVD2SVCD and I've burned them out using my CDRW drive on CDRWIN (teac cdr). They play just fine in my Pioneer DVD-503.
When I try to burn the exact same cue/bin using CDRWIN on my HP 9900i on CDRW it burns just fine, but when I try to play it in my Pioneer it shows up as a CD and just says 'search' and the counter moves forward twice as fast.
If I burn the same cue/bin using CDRWIN again on the HP 9900i (this is all on the same computer mind you), using NERO it plays just fine in the Pioneer. I've read that I should not count on Nero for cue/bin files as it might glob things up.
Why does CDRWIN work just fine on the CD-R's, but screw up the CD-RW's???
Regards,
Roveer
Results 1 to 1 of 1
Video not showing
By Clem Porterhouse in forum DVD RippingReplies: 4Last Post: 31st Mar 2011, 04:06 -
DVD showing 60 GB size
By brucexx in forum DVD RippingReplies: 7Last Post: 30th Mar 2010, 15:22 -
Subtitles not showing
By marukomu in forum SubtitleReplies: 17Last Post: 16th Nov 2009, 20:39 -
subtitles showing like chinese
By forare in forum SubtitleReplies: 1Last Post: 20th Aug 2009, 08:20 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51
