hey i have the ati tv wonder ve capture card and i was wondering it its possible to capture into mpg rather than the default avi. when i capture, it seems the only choice i have to save is a special ati compressor or something that came with it. so....i heard other people capture into mpg and i just wanna know how, it its possible for me
I personally think you'll be disappointed with capturing directly to mpeg-1 vcd format, better off sticking to mpeg-2 or .avi caps. I speak from personal experience. mpeg-1 caps are almost unwatchable on tv.
"The software said Win XP or better, so I Installed Linux" -
Try using one of Intervideo's windvr programs (latest version is 2.0 i believe). For real time capturing to mpeg1 the quality is not bad at all. I have captured plenty of times to vcd and they are defineately watchable on tv. Better than any other real time mpeg1 capture progs ive used. It does a pretty good job at mpeg2 also.
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
