Hey all,
I'm having a weird one here. I'm encoding a two hour movie file of TV shows. I have about five total, and all are the same settings. All are 1 GB's in size, all are about 2 hours long, and all use the same DVD compliant Encoding settings.
At least it works with My DVD. But the problem with My DVD is that it has to convert the Audio, causing more space on the Disk to be used up. Too much, in fact. So, I decided to use Ulead DVD. This one dosn't convert the audio, but it dosn't recognise my MPEG file as a valid file. It keeps on giving me an error message.
However, I try another file that was encoded with the EXACT Same settings, and same hours in length, and it works perfectly.
Any ideas? I'd also be interested in programs like Ulead that don't need to encode the 48KHZ of audio to Dolby Digital like Sonic does.
Thanks!
I had the same problem, didnt accept my files encoded the exact same way as files it accepted earlier.
The really wierd thing is that when I tried an hour later with the same files it authored and burnt my disc without any problems..
Unfortunatly, I just tried them again today, with a 5 hour difference, and it didn't accept it at all
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 08:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 13:12 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 10:59 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
