Can someone tell me is there anything other then Nero that supports burning DVD video format? (That supports the DRU500A)
The last version of Prassi doesnt recognize the Sony.
Like nero that I can drag my VIDEO_TS contents into and it supports the
Sony DRU500A or is Nero the best bet right now?
Results 1 to 16 of 16
Recordnow Max is another one you can try. I have no experience in burning DVD-video yet though. might try that this weekend
Thanks but the DX version of Recordnow max doesnt support the DRU500A, and the version that comes with the drive is the lite edition I think. There is no option for doing DVD video.Originally Posted by ferrari
Anyone know any other app that will work with the DRU500a for doing DVD video burning? -
Sonic MyDVD works but you have to use their silly menus.I tried ArcSoft
Showbiz to burn but I keep getting"drive is busy" error.
Read this thread:http://www.vcdhelp.com/forum/viewtopic.php?t=127624&highlight= -
i have my dvd 4.0 and it i make my own menus just got to import teh pics you want for a menu.....
RecordNow Max 4.5 supports the drive and works great for DVD Video and all my other DVD burning needs too.Originally Posted by crimpshrine
RecordNow DX is another version of RecordNow, and is not to be confused with RecordNow Max. -
ditto on the recordnow max 4.5 and sony dru500a, very fast initialization of the disc as well
Thanks for the clarification!Originally Posted by VEFF
I now see what your talking about, I will have to give that a try also.
I see 4.5 refered to as Stomp's?
Thanks again. -
VOB Instant CD/DVD version 6.5
Gear Pro Professional Edition version 6.02
Both of the above have worked very well for me writing to my Sony DRU-500a. VOB Instant is simpler and a little quicker, but it doesn't seem to actually do any checking of the files in your VIDEO_TS folder. Gear Pro takes a little longer, but it does check your files. Several times Gear has warned me that I was about to waste my time burning a DVD that would never play. (Errors like forgetting to do a final "GET VTS SECTORS" in Ifoedit.) -
Thanks, I have been using Gear and Nero. Gear when it's media that I know only will burn at 1x (for some reason it only gives me 1x as an option with any DVD-r when using nero I can burn certain media like the riteks at 2x)Originally Posted by henry_nettles
I will have to try the other application also. (I try to verify my DVD with power dvd first before burning anything.) I have actually had Nero complain and I have already verified with power dvd, and even after the burn after nero complains it plays fine in my home DVD player.
Thanks everyone -
to henry nettles:
How did you manage to get the Instant cd/DVD working. Did you install any specific drivers? My version 6.5 recognises the drive, but does not find any disk in it even if there is a blank DVD in it. I have the latest firmware 1.0f.
Thank you for the response -
You can download the Record Now DX for free on the same download website for DLA. It is the more powerful version of the Record Now that came with DRU-500A
best free software to burn dvd?
By sgbd in forum Authoring (DVD)Replies: 10Last Post: 17th Oct 2010, 08:57 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Best software to burn my dvd files
By superJT in forum Authoring (DVD)Replies: 10Last Post: 18th Aug 2008, 21:35 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 08:35 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
