ok, so here's the deal, i have a bunch of mpeg files i recently downloaded, 29 to be exact, that i would wish to convert to divx because of their size, which range from 200mb to 250mb. now, what i was wondering was if there was a way to add all of these files to a queue list and maybe leave them to convert over night or so, thanks.
Results 1 to 9 of 9
good times...
Absolutely. Use the wizard on TMPGEnc. Load the first file, set up the parameters, and the last option lets you add it to a batch file. Repeat until all 29 projects (files) are loaded, get ready for bed, then tell TMPGEnc to execute your batch file -- Nightie Night!
Hello. -
someone should write a problem that u drop a bunch of AVI's in (assuming they all use the same profile) and have it write a batch file for TMPG.
Originally Posted by nyfehTMPGenc can encode TO DivX ??Originally Posted by Tommyknocker
yes --- file -> save as -> avi -> type divx
but i dont think this can be batched except by a real round about way ... -
I made a mistake. You can do batch processing of DivX files on VirtualDub, not TMPGEnc. VirtualDub calls it "Job Control. A job is loaded by checking the "Add Operation to Job List and Defer Processing" box on the Save As requester. Then once all jobs are loaded, select File-->Job Control. When the box appears, selecting Start begins the batch processing.
Hello. -
would there be a way to say, set it to convert a whole directory with like 50 files, using the same setting for each one?
good times... -
you can batch files to 1 file in newest tmpgenc .. but only if the source is avi ...
you can batch file any type of supported file into one file w/ Main concept ...
you can batch any type of supported file into one file w/ CCE
Mass conversion to multiple file formats
By Haopengyou in forum AudioReplies: 8Last Post: 11th Aug 2011, 02:35 -
Queuing up in ffmpegX
By indijay in forum ffmpegX general discussionReplies: 4Last Post: 24th May 2010, 06:23 -
mts or m2ts playback via Media Center x64 Vista possible? queuing them too?
By markm75 in forum Media Center PC / MediaCentersReplies: 4Last Post: 10th Nov 2008, 09:07 -
Mass conversion of Office 2003 files to Office 2007?
By Xylob the Destroyer in forum ComputerReplies: 8Last Post: 17th Jun 2008, 00:06 -
Best conversion method for mass DVD to DivX
By spidey in forum Video ConversionReplies: 3Last Post: 1st May 2008, 08:29
