Results 1 to 10 of 10
  1. How can I get Gator spyware off my system? When clicking uninstall it says to go through add/remove programs, but the file "GAIN" it states to remove is not listed in XP under add/remove.
    I use both Mac and PC. Mac: G4 Power Book 1GHz w/1GHz ram PC:1GHz w768 both have large SCSI/Fire Wire HD
    Mar 2002
    Milwaukee, WI USA
    go to www.download.com and look for a program called ad aware. it removes all sorts of adware/spyware programs.
  3. For future reference, no install any thing called GAIN, GATOR
    BONZI BUDDY, etc, these little addons infect ur system,and
    you can NEVER really get rid of them, u can run adaware all
    you like, they still come back......try system restore NOW, while
    you can, if your install was recent, if not well what can one do anyway
    its free right?why you think it is? they bomb you to death...
  4. Originally Posted by musher70
    As Milton Friedman wrote, "There's No Such Thing as a Free Lunch"!
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  5. try spybot search and destroy. Do a search on google.com and you shouls find it.
  6. Originally Posted by markpilkinton
    I used Ad-Aware, but after Ad-Aware cleans registry and some files you still need to delete rest of the files manualy. Result ? I was not able to use DixX anymore because it was complaining that "spyware" was missing and since its "free" that is your "price".
  7. try jv16 powertools, it like a easy reg cleaner,in came
    on the new maximum pc disc last month
    http://www.vtoy.fi/jv16/shtml/software.shtml
    Jun 2001
    Surface-of-the-Sun (AZ)
    Well, some of us would never install spyware in the first place (they DID tell you it would be installed). Since there is another free version with no spyware you have two choices: the lite free version or pay $30 for the full version. If you're only decoding there's no reason to bother with the spyware version or the pay version (as the pro features are only used for encoding, and I don't know if they're really that important).
    Jan 2002
    You might try to kill it in the start ups menu.
  10. just read this guide and you dont have any problems with Gator...
    http://forum.doom9.org/showthread.php?s=&threadid=19583
    8)
    Zzzzzzzzzz
