Hey guys,
I'm gonna be in the market for a dvdr after xmas, and i just wanna clear up a few questions i have... to justify buying the burner.
Can I put multiple divx or xvid movies onto a dvdr and just use a menu to play the different ones?
I doub that standalone dvd players support the divx/xvid codecs, so can it be done?
Thanks for the help guys!
P.S. - I put this post in here, as I had NO idea where to post it LOL![]()
Standalone DVD players do not support Divx, so no it cant be done, the way you want. You could however convert your Divx to mpeg and burn as DVD or VCD-DVD and play them on your DVD player. You could then have more than 1 movie accessed via a menu.
If you are goung to convert use TMPGEnc, this has templates for VCD, SVCD and DVD. This way you know you will be making a compliant file. MPEG1 for VCD, MPEG2 for SVCD or DVD.
Divx\Xvid 2 DVDR
By eliqush in forum DVD RippingReplies: 9Last Post: 14th Jul 2009, 09:48 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 09:57 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
MPEG2-TS (multiple audio tracks) to DivX/XviD
By cecco in forum Authoring (DVD)Replies: 3Last Post: 31st Jan 2008, 10:05 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 04:28
