Just hooked up my new ADVC-100 to a Belkin Firewire Card (uses Texas Instruments chipset). When I try to capture with Premiere 6.5 nothing shows up in the capture screen. It's like no signal is getting through that Premiere can detect. Any suggestions?![]()
I don't know about Premiere 6.5, but I could never get a decent capture with Premiere 6.0 and my ADVC-100. I use Pinnacle DV Express or the Ulead software that came with my Firewire card to capture and then do the editing in Premiere.
Please read known issues with ADVC at the Canopus website. It isn't compatible with TI chipsets.
Try switching hardware control off in premere.
Also has the device ie the ADVC been detected in System as sort of capture device?
Also test things are working with the freeware DVIO app -
A slight update
Check to make sure device is in system.
Usually under Imaging Device it will say something like
"Microsoft DV Camera and VCR"
In Premiere 6 or above check that in "DV Device Control Options" that
Video Standards set to PAL or NTSC
Device Brand = Generic
Device Model = Generic
Timecode Format = Non Drop-Frame
and its status should be online
Canopus ADVC 300 DVD Capture Now?
By Detta in forum Capturing and VCRReplies: 7Last Post: 20th Sep 2011, 14:02 -
Canopus ADVC 110 or Canon HV40 for Best Capture
By jaydub in forum Capturing and VCRReplies: 4Last Post: 21st Sep 2010, 15:55 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
Capture Software Needed with the Canopus ADVC-110 ??
By christopheramos in forum Capturing and VCRReplies: 15Last Post: 23rd Feb 2009, 16:42 -
Capture problem with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 26th Dec 2007, 21:20
