Ive downloaded heaps of mpeg splittler and i have never found one that i actually like, each one always has something stupid about it.
I was just wondering what the majority of you use.
8)![]()
:P
By split I assume you mean cut. If all you want is to demultiplex then TMPGenc is all you need.
If you are using mpeg1 than TMPGenc should do the job the majority of the time. If you are using mpeg2 than the only cutter that can properly do the job every time is bbmpeg. I've tried them all and in my opinion nothing comes even remotely close to bbmpeg.
Best freeware MPEG-2 splitter?
By ANOther1676 in forum EditingReplies: 26Last Post: 4th Feb 2011, 15:59 -
Haali MPEG (PS) Splitter
By zawmn83 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2010, 23:33 -
MPEG-2 Splitter for MPC
By cheerful in forum Software PlayingReplies: 19Last Post: 22nd Sep 2009, 23:15 -
MPEG Splitter
By Amanaman in forum Newbie / General discussionsReplies: 12Last Post: 5th Sep 2009, 15:28 -
MPEG-2 Splitter?
By therock003 in forum Software PlayingReplies: 1Last Post: 22nd Jul 2008, 11:24
:P
