When I play certain .mpg or .avi files I get the audio a few seconds before the video. I am running win ME and using windows media player 8.0 I think. I don't think it has anything to do with my computer and it may just be the files. I have tried other players and it is the same. I also have one DVD that does the same. Is there anyway to fix this? I don't think it is a Codec issue but I could be wrong. Is there a very cheap or even FREE program that could re sync the audio on mpeg's avi's or even dvds. any help or advice would be greatly appreciated!
There are a couple of ways to fix this. Instead of just telling you I will direct you in the right direction. On the left, click on the frequently asked questions and scroll down to audio. There is a link that tells you how to correct this.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Video/Audio Sync HELP!
By Fractalz in forum EditingReplies: 3Last Post: 26th Jan 2011, 15:06 -
video out of sync with audio
By Moparbear in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 21:48
