I am trying to copy a DVD using OSex. When I look at the file properties of the DVD, it says 7.71GB. But when I open up OSex, it says the file size is 3.79GB. If I just do a straight copy using OSex, will it work properly or do I need to use Process #2 as described on this website:
www.anycities.com/user/bilestyle/index.html
Go to Tutorials > OS.x.x > DVD to DVD-R/Downsampling. Thank you for your help!
Results 1 to 1 of 1
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 04:31 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
I can't reduce the size of a file using AutGK - "no fps"
By HartsVideo in forum EditingReplies: 38Last Post: 3rd Jan 2009, 23:02 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40
