  1. I'm using TMPGenc to convert some .avi files into Mpegs. The Vido is transfering just fine, but there is no audio or an small numeric error message keeps poping up every 2 or 3 seconds during the conversion.
    I know the error message is being couse by the audio. Any idea what can be done?
    Thank you
    Dreams fuel our existence.
    Apr 2002
    The State of Frustration
    See if you can extract the audio from the video before encoding with TMPGEnc. The use this separate file along with the original video to be muxed into a new MPEG file.
    Hello.
  3. Try changing the VFAPI Plug-in order (options meun, environmental settings, VFAPI plug-in) and either make Directshow Multimedia file reader top OR decrease so it is not top. This sorts out those errors.
