i am using xp pro and have backed up several dvds without any problems or issues however. Dvd maestro is causing one major problem with my pc, when the program is installed i can not shut down the computer. This in turn is causing system wide problems.
Any assistance would be appreciated.
Regards
Nick -
I thought DVD maestro could only be used on windows NT, although I may be wrong.
I've heard of other people using it on XP, but you can't run the Cinemaster 2000 needed for realtime preview.
That is a very odd problem and Maestro does work fine on XP (NT based).
Also you can install another DVD player pack and get realtime preview on XP (forgot the name, someone mentioned it on these forums not too long ago).
As far as you not being able to shut down, very odd and I'm sorry I can not help. -
Thanks for your response
I have made some enquiries, it would appear that i am using version 2.11.15.0, could this be relevent. If so can any one recommend a location where i can obtain an upgrade.Regards
Nick -
Maestro is no longer available and a place to download any version is not available (unless you know someone who has it or you are very resourceful).
Thanaks all.
This presents quite a problem,
Can any one recommend a substitute programRegards
Nick
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 04:22
