Right!
TMPGEnc crashes whenever i quarantine an infected file called SysMap.exe. Norton reckons it is a Backdoor.Trojan. I have freed the file and used TMPGEnc to encode a file and it works fine, but as soon as i move it TMPGEnc crashes!
Ive tried different avi files aswell so it isnt the file im encoding that causes the problem!
the file is in the c:\windows\system folder (WinME). Does anybody know if TMPGEnc actually uses this file?
This is a new one on me so help is appreciated!
If you cant dazzle em' with brilliance, Baffle em' with Bullshit!
I would quarantine then delete the file in Norton. Then I would uninstall TMPGEnc and then download a new version off the internet.
I tried that several times and it still crashes! ive uninstalled all the codecs and appz that i use in conjunction with TMPGEnc and it still crashes!
Thanx for the reply anyway mate!If you cant dazzle em' with brilliance, Baffle em' with Bullshit! -
everything! ive wiped the pc clean now anyway!
cheers!If you cant dazzle em' with brilliance, Baffle em' with Bullshit!
XMedia Recode Crashes when going to "Filter/Preview" tab
By BoxesofBags in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2012, 12:46 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Ulead Video Studio SE 9 Crashes on "Create Disc"
By Canopus Smoker in forum Newbie / General discussionsReplies: 6Last Post: 29th Nov 2008, 16:46 -
ffmpegX jumps to "finished" crashes computer, lost progress.app
By jegler in forum ffmpegX general discussionReplies: 16Last Post: 2nd Jun 2008, 19:53 -
quarantine
By musclehead in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 12th Jul 2007, 04:13
