Which setting are best????
Cable select or Master\Slave???
Master / Slave
depends -- if two devices are on same chanel and both are fairly recent vintage and support cable select - > go that route
fail safe -> set one device to master (end of cable) and other to slave ...
one device on cable set to master or (on some drives) master with no slave jumper setting .. -
Its a new Dell.... and I just got the new sony Dru500a
So will I go with cable select.... My existing Harddrive and DVD reader are set to cable select -
As long as the drives support it and you have the right cable there is no difference other than jumper settings, and that master/slave is now determined by cable position. If you must put two drives of non-identical performance on one cable, the faster one should be Master.
Slow Data Transfer from Slave to Master
By jollyjohn in forum ComputerReplies: 15Last Post: 9th Oct 2009, 00:48 -
Need slave function for capturing
By doggyjumper in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 11:06 -
Which Burner for do I set as Master/Slave
By mn072065 in forum DVD & Blu-ray WritersReplies: 12Last Post: 17th Apr 2008, 09:46 -
"Master" Master Audio Volume Control?
By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 08:57 -
slave drive seems dead, but cannot boot without it
By ted demen in forum ComputerReplies: 11Last Post: 13th Jun 2007, 07:54
