I have a pixelview TV tuner card and i use it for video capture.When i convert captured video to VCD using nero it plays fine on My computer But video jitters when i play it on a VCD player.
I use power director software (OEM Version) to capture and edit my video.I burn my CD at 4x speed.I have P4 with 128MB ram and onboard AGP and sound.
Use something besides nero to convert your video. nero is the worst at converting. Use TMPGenc or some other encoder software. Look in the tools section over there <--------------!
kinda wondering if the problem I'm having is similar. I converted using avi2vcd. The resulting images can be viewed on my PC, but when I tried to burn to CD with Nero (expired useage) little square boxes showed up on the VCD being viwed on my DVD. I got the same result with VCDeasy v1.1.3. I know my DVD will play VCDs and I have a disc made on a MAC (titanium) that works. I'm inclined to believe it's the convertion process that I'm having dificulty with. Do you think TMPGenc is something I should try? (Thanks)Originally Posted by SLBOSS926
Jittery Flickering!
By Soixante in forum ComputerReplies: 4Last Post: 27th Sep 2010, 07:11 -
DVD To Xvid - jittery, please help?
By kpoman in forum Video ConversionReplies: 5Last Post: 25th May 2010, 18:59 -
jittery slow motion scenes
By Dr_Layne in forum Capturing and VCRReplies: 1Last Post: 25th Aug 2007, 20:36 -
burning avi file is jittery
By fredted40x in forum Video ConversionReplies: 1Last Post: 4th Jul 2007, 12:48 -
Jerky, Jittery DVD
By leng in forum Newbie / General discussionsReplies: 18Last Post: 24th Jun 2007, 11:15
