alright... have been trying to convert DivX movie to VCD/SVCD with TMPG Beta A and it wont decode the sound! and if i use a higher version it says it cannot find the sound! help me plz!
Hmmmmmm. I can't help, but I want to add to the inquiry. After I capture an AVI with my AIW Radeon, I use TMPGEnc 12i (or older) to convert it to SVCD NTSC. Everything looks fine, but 2 minutes ± into the resulting mpg file, the audio cuts out. Just goes silent for the rest of the file. It just awful. It takes so long to make and they don't work.
I checked the original AVI to make sure it had the audio all the way through, and it does. So the TMPGEnc seems to be at fault. Anyone know why?
/\/\aetryx -
I can help you both! I had the same issue, the original AVI was fine, but the encoded MPEG's audio (From TMPGenc) quit after one minute. Check out the "How To" Convert on the left of this site. It states if there are audio troubles, convert the audio file to WAV (only takes about a minute per 10 minute AVI), using the freeware VirtualDub. Then, in TMPGenc, browse to add AVI video file and the audio WAV file, and start encoding. It works!
Hey, cool! Thanks for the tip, man. I've been really "lamed out" by the whole experience, and now you've "un-lamed me out". I need better metaphors.
/\/\aetryx
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
