Newest version has a video window that allows chapter points to be selected visually. I did this but the resulting VCD had all of the points several seconds too early. Anyone know what is going on?
Thanks!
reman
I think it may have to do with I-frames. An I-frame is selected at the start of every GOP. The reason why your chapters are a few seconds probably is because that your I-frame started a fewer seconds later than you wanted it to. I-frames help your chapters stay in sync when jumping from one chapter to another.
Hope That Helps!!!
:P
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 05:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 21:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 21:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 09:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 16:13
