I purchased a HP computer with the new microsoft media center os. The media center records from TV in a dvr-ms file format. Does anybody know anything about this format. I would like to export these files to antoher more useable file format.
i hear a mess and not transportable - is this true ? someone BOUGHT one of these machines ?
what can you do with this file other than play it back on only machine its recorded on ? -
Plays back on xp sp1 w/ media player 9 machines right now will by the end of the month or next MS will opne the format for dvd recording. '
I'm work on a way to rip out the mp2 code. Love the machine thought, wonderful entertainmet center. With a few tweak it will be great. -
I've been poking around with converting the ms dvr files to AVI using
graphedit. I've had a problem in that the conversion runs for a while, then dies with an error message that
"The sample start time is before the end time".
I have discovered more or less what this is. The audio stream coming
out of the decoders appears to "hiccup". The hiccup takes the form of
an IMediaSample that has the "discontinuity" bit set. It also has its
timestamp reset to zero and this is what graphedit is complaining
about.
I was able to get complete conversion of ONLY the video portion of the
file by running the audio into the Default DirectSound renderer.
During the initial part of the conversion you hear the soundtrack.
When the hiccup occurs, the sound stops, but the conversion continues. -
didnt i read this encoded like tivo in that it switches back and forth from 24 to 29 and adjust on the fly for best picture --
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
Conversion of DVR-MS to Standard Mpeg2 Format
By jaffacaique in forum Video Streaming DownloadingReplies: 2Last Post: 13th Apr 2009, 04:40 -
curious dvr-ms format and conversion
By todds1 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2009, 04:38 -
Windows Media Center dvr-ms format
By todds1 in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 15th Sep 2007, 03:37 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
