I recently bought a tdk dvd burner and am trying to capture and burn using ATI all in wonder and Ulead DVD Factory and Ulead DVD Workshop. I have tested and tweaked about a thousand times now. I almost always get audio sync problems. on a couple of occasions i got good results on the pc, but when i burned them to dvd, they were blurry or choppy during fast action scenes. I used DVDXCOPY to copy a dvd and it came out perfectly, which leads me to believe the burner is ok, but that is just an assumption.
I would appreciate any thoughts, or suggestions as to what i can try next.
Thanks!
ATI real-time captures are slightly non-standard. De-mux the file with TMPGenc, Re-mux with BBMpeg, image with VCDImager, burn the bin/cue. Do not edit.
Make sure you're using the latest version of MMC (7.7).
You shouldn't get any audio sync issues. -
Yes, 7.7.0.1 (I think) gives me no synch errors at all.Originally Posted by SulikAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Yep 7.7.0.1 here. No sync problems.
Warning! I'm baaaaaaaaack
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
Capture software for ATI HD Wonder 600 PCIe
By Spektre in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2011, 09:31 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
I can't get my ATI tv wonder PCI 650 to capture
By Onceler2 in forum Capturing and VCRReplies: 5Last Post: 28th Nov 2009, 10:47 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11
