Ok, i bought my burner about a year ago, and in that time, i have had to wipe out my computer a couple of times because i had too much crap on it. Now i figure out that my burner will not copy any CDs using Nero 5 or CloneCD. They both go a little way, CloneCD says that it was unsuccessful, and Nero just keeps saying every 15 seconds, "Error writing to drive C: data or files may be lost" Now, i think this is because i do not have the installation disk that came with the burner anymore. I lost it. I can't find it. If anyone generous enough with this burner could send the files off of the installation CD, please send them to mudv_ayne@yahoo.com or on AIM at xYxMuDvAyNexYx. Thanks ahead of time.
If I were you, I would start making some "final arrangements" for your hard drive, it has nothing to do with the burner.
Realmedia! The Nectar of the Tards! -
Even if an install disk would work you haven't given us enough info to help you! We would need model name & type.
How can there be a hard drive problem? I totally wiped out the hard drive and started over with the original stuff i got when the computer last year. And if it is the problem, how do i solve it?
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 01:47 -
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 21:47 -
UGH!!!! READ problems again, this time with Sony DVD burner Sata 22x
By Clint Eastwood in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Feb 2009, 01:31 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49 -
Dvd Burner only reads older dvds, won't read newer ones all the sudden??
By kpaxfaq in forum DVD & Blu-ray WritersReplies: 6Last Post: 28th Feb 2008, 14:11
