Got this subtitles file that I'd like to edit, but as I'm new to the subtitles business, I don't know what format it really is in:
It has a .sub extension but is in text format.
Each line starts with start and end frame in curly brackets like {startframe}{endframe}texttext textText
Line breaks are entered with pipe (|)
When I try to open it with Subtitle Studio, SS just freezes up, so I guess it is expecting something else than what it actually gets, making me believe that the .sub extension is not correct...
Anyone who knows the source of this sub, and what the extension ought to be?
/Mats
The format you mentioned is definetly .sub.Originally Posted by mats.hogberg
Have you tried opening another .sub extension file with subtitle studio?
Maybe the problem is in the software and not in the subfile.
Anyway you can simply manually check for errors. The format you wrote is correct no need for anything else in that file -
Thanks - I opened it with "Subtitle Tool" (tomzavodny) and saved it out as SSA. Now Subtitle Studio opens it fine, even if SS has a problem with one of our umlauts (å/Å)...
/Mats
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 16:52 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
How do you rip subtitles from a DivX file w/4 subtitles
By JoeBolden in forum SubtitleReplies: 2Last Post: 21st Nov 2007, 14:46 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
