  1. Im in the market for a portable DVD player
    With or without a screen
    It needs s-video output
    It needs optical output
    It needs to be pretty feature rich:
    *play svcd and vcd on cd-rw and cd-r and xvcd/sxvcd wouldnt hurt either
    Im looking for a portable replacement to my crappy Kenwood DVD player that barely plays anything (plays VCD once in a blue moon but it has to be a super high quality cd-rw slowly burned)
    Your help in my portable DVD player search is appreciated
    edit: shouldve also mentioned that im looking for the lowest price possible while still satisfying the above conditions (and doesnt spontaneously burn up in flames or anything like that)
    Jul 2002
    Scotland
    I have a Panasoniv LV50.
    Plays great, have not been able to test on DVD-R/W
    dlb.
    Apr 2002
    California
    looking for on with no lcd screen. go with the koss dvp2161 at your local Target Store. It goes for $99 bucks. sometimes even for $49 buck that if you lucky on the day it on clearess
    There is always one who is always greater. Never give up.
  4. I have the Panasonic LA95, which has what you are looking for. I've been able to play dvd-rs, svcds on it.
    I'm very happy with the quality and features.
  5. I got koss dvp2161 and it has s-video, optical output and standard RCA output. It play every thing. VCD, SVCD, DVD-+R/RW but It doesn't have DTS output. I'm using this player with Sony PSONE 5 inch monitor for long trip. My daughter was happy with it.
  6. Originally Posted by marisag427
    ouch, that one really sets you back
    wish i had a ton of money to blow
    for that much id probably just get an adequate laptop and use that
  7. "ouch, that one really sets you back
    for that much id probably just get an adequate laptop and use that"
    well, I have a laptop for work that has a dvd player but it is so much bigger. I actually splurged on this for several long plane trips I was/am taking with my less than 1 year old son this year and so far it's been worth the expense! Nothing like Rolie Polie Olie or baby mozart to keep him occupied for several hours.
    Jun 2001
    Silver Spring, MD USA
    I have the RCA 5400P (a Shinco clone). It plays all the formats you listed very well. It even sometimes detects the difference between properly authored SVCD (480x480/576) and CVD (352x480/576). It plays pressed DVDs flawlessly, and only sometimes pauses briefly during the layer switch. It runs really hot after about 100 minutes, and this excessive heat caused the little rubber feet on the bottom to move around. I havent met a portable yet that didnt run hot, so you'll have to accept that little drawback. It plays Apple DVD-R flawlessly but won't play any DVD-RW I've tested (if there are others, I don't know about them). It supports MP3 playback but chops off the first two seconds of each song, so don't rely on it for that functionality.
