I am trying to convert VHS(pal movie) to VCD .For that ,I have a bt878 card.
I use iuvcr with Divx 5 compression (352*288 pal @ 25fps)and then TEMPGenc to convert to mepg1.I burn the cd with NTI CD Maker 5.
Although the mpg output is less brighter (perhaps due to compression) the quality is satisfactory when played on pc. But when I play it on a vcd player although I get the brightness back the image is dirty. I have tried to change some parameters like compression, color format without success
Please help me
Thanks Nawaaz
Did you notice that the dirty part only happens when the video scene is complex? Does it look good somehow when the video scene is simple such as the closer shot of certain object. If that's the case, your video might not be suitable to be on VCD format. You need to consider SVCD, XVCD, XSVCD, CVD or DVD at higher bitrate.
Sometime it just depends on the nature of your video... -
Nawaaz,
I could be totally wrong here - but I think part of your problem might be using the DivX format for the capture, then converting to mpeg1/vcd.
As far as I know, DivX is quite a 'lossy' format - so when encoding to mpeg1, the quality isn't so good because the original source isn't very 'data rich'.
If you've got a bt878 card, you might want to try something like VirtualDub and the HuffyUV codec for capture (which is supposedly 'virtually lossless') and then encode with TMPGEnc to VCD format.
The quality I get from this method is really good - the only slight drawback is you need a fair bit of disc space to do a big capture. I think capturing at PAL/VCD resolution to Huffy, I get roughly 10mins per gigabyte of .avi file.
'hope thats of some help,
mcdruid.
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Good DVD's gone bad - Emerson
By merinski in forum DVD & Blu-ray RecordersReplies: 21Last Post: 12th Oct 2007, 09:26
