Hey guys, this is mostly an audio question, regarding xvid.
I had a 750mb xvid movie which was encoded ac3 audio, i used graphedit ok to extract the audio, and everything worked fine. I then used framserver in virtuadub, along with tmpgenc, and everything worked fine and the final size of the mpg was 540mb.
Now i have another xvid movie, roughly same size as last one, but with a different audio (i.e. not ac3), when i use virtuadub to extract the audio everything is fine, but after i have done frameserver+tmpgenc, the mpg comes out to be more than 900mb?
My question is, what options are there for me, (im thinking in terms of audio), so i can reduce the final size of my mpg so it will fit on a standard 80min cd, like when the previous mpg had ac3 sound, and came out to fit on a cd.
Thanks in advance,
tony_soprano
Results 1 to 1 of 1
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 14:37 -
MPG File Size and/or Timing Help
By GearBeer in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2009, 11:21 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 20:56 -
XviD and DivX file size
By timmer545 in forum Video ConversionReplies: 2Last Post: 9th Nov 2007, 15:30
