  1. Is .mpg the same as mpeg
  2. This wasn't a dumb question was it? I'm really new to this. I have a bunch
    of .mpg's that I want to convert to CD-R OR CD-RW and play on a dvd player. My DVD player is a Audiovox dv-1680, supports svdc and vcd.
  3. no not a stupid question!
    .mpg files are the same as .mpeg files
    .mpg are probably the most common cause of good ol DOS and the 8.3 file specification. old habbits die hard
    XnakX
  4. Thanks, xnakX. I,m having a hard time with instructions on this site
    for converting some .mpg's to scvd to play on a dvd player. Does
    it have to be mpeg2 to convert to svcd?
  5. Yes it has to be mpeg2, it is svcd
  6. Can you make any mpg svcd?
    Sep 2001
    Japan
    Only m(e)pg which are SVCD compliant, can be made into SVCD.
    Compliant means:mpeg-2 compression, correct framesize/framerate and bitrate (look at at what is:SVCD on the left of this forum).
