At the last seconds of burning my DVD, I got an error that read:
Generic error from CD/DVD recording software. Please make sure the device is ready and try again.
Error: TAO-240-SPTI-00-02-05-72-03
Can anyone tell me why this happened and what I can do to fix it. Thanks.
I get the exact same problem when I use ULEAD DVD Movie Factory. I hope someone can solve our problem.
Paisano -
A couple of things to try:
Make sure that Autoinsert Notification is turned off for the drive.
There are times when the burner starts to write the leadout, the drive will attempt to read the media if Autoinsert is ON.
Another fix that often works is to disable DMA on the drive and set the mode to PIO.
This may limit the max burning speed depending on your computer confguration but can save a lot of trashed media.
As always be sure that no TSRs are running on your system while burning and have the screen saver disabled.
Hpoe this helps !
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 09:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55
