Being fairly new to this conversion business I have found this site to be an invaluble source of information. However one thing I have come across is what seems to be a fairly new format called MP43 and have been trying for weeks to try and find a way to encode these files to Mpeg1 to turn into VCD. As have ,or so it seems, a lot of other people.
Anyway I seem to have found a cure. I hope this will help others.
I have two small programmes I use , Both are available at www.divx.com
the first is GSpot and the second and most important is FourCC Changer.
I first open the file in GSpot this shows me all the codecs in the file , i.e MP43 and MS Mpeg4v3. Close GSpot. Open 4CC Changer. Browse for the file and open it . In the description code enter 'div4' and in the Used Codec enter DIV3 , then click apply. It's as simple as that.
Look at the file again in GSpot and there is that nice Divx3 codec that we can run through TMPGenc and convert to Mpeg1.
I hope this works for you.![]()
Man you are a lifesaver ive been trying find the answer to that problem for months now. Thanks
or you could just download the mp43 codec, http://legoman666.netfirms.com/mpg4vki.zip
Time's not wasted when you're wasted all the time.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
FFdshow DivX 3 MP43 + Purple Marks
By Baharroth in forum Capturing and VCRReplies: 1Last Post: 26th May 2009, 08:31 -
Sound Card - Cure for My Sync Errors ?
By mrlewp in forum AudioReplies: 13Last Post: 9th Apr 2008, 19:20 -
Lesbian worms! Is this a cure for homosexuality?
By moviebuff2 in forum Off topicReplies: 9Last Post: 30th Oct 2007, 08:43 -
Is DivX(Xvid) A Cure For NTSC/PAL?
By hech54 in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2007, 12:13
