I want to make "best of" dvds w/ the best parts from my collection. You know, some VOB files from here, some from there, etc. BUT, I only want to watch them on my computer; don't need to have it compatible w/ a dvd player. I only tried divx4 so far.
I tried a program called Flask and followed the tutorial to convert to divx4. The picture quality was acceptable, but the thing I hate about divx is when you want to skip around to other parts while watching, it's DIRT SLOW. Or is there a way to fix this?
Also, is there a way to "batch process" multiple VOB files? The Flask program was easy enough, but it won't do batch. I looked at Gordian, but it seems too complicated?
Finally, should I just skip this all and rip everything to DVD-R instead??
if you have a DVD burner, i'd do that!
if it's just for computer use, then DIVX yes.. try the latest version though, i think it's up to DIVX 5 now..
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Flask isn't quite the best. Gordian Knot is much better. I basically skipped DivX 4 altogether. 5 works good enough. DVD-R, sure, if you can afford the drive and a couple hundred media at first...
Can you Rip DVD to 740 or 1080 format?
By laithmeister in forum DVD RippingReplies: 18Last Post: 9th Feb 2014, 15:10 -
Controlling the format of a DVD rip
By m47 in forum Video ConversionReplies: 1Last Post: 18th Jul 2011, 07:33 -
Mac format HD DVD, How can I rip?
By haymes in forum Newbie / General discussionsReplies: 16Last Post: 22nd Mar 2009, 16:45 -
Rip DVD to DIVX with the same quality
By jujuandhuhu in forum DVD RippingReplies: 20Last Post: 12th Apr 2008, 13:43 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 19:11
