  1. Please help me how will i be able to convert the MPEG2 file to an VCD compatible MPEG1 fomat. I tried TMPGenc encoder, it won't recognize MPEG2 format.
    May 2001
    London, UK - Bonn, Germany
    Usually TMPGEnc will give you no problems whatsoever. Make sure you downloaded and installed the TMPGEnc correctly. Don't forget to download and install the VFAPI Plugin for TMPGEnc correctly as well. If after this, it still won't recognize the mpeg2 file. Try downloading and using the mpegcorrector from this site (Under "tools" section) and then try again. Have you tried viewing the file on your pc?
