Hi.
I am presently 'experimenting' by changing the bitrates on a program called FLASH. It seemed to work GREAT when I copied a VCD, but when I did the same thing, this time trying to obtain a SVCD, it took TOO much space on the CD.
The question I have is where do you change the bitrate on THIS program (Hopefully 1 of you are using it) in an effort to get a couple of chapters on 1 disk....instead on just one? I'm using the standard audio rate, but don't know where to change the video. I have used the calculator and have figured out my numbers too!
Thanks.
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 11:17 -
WD TV reccomended bitrates
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 2nd Nov 2009, 00:20 -
I need some help understanding bitrates...
By pwhyles in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 14:54 -
MP3 Bitrates..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 22:50
