  1. Ive ripped Vob's from a DVD and used DVD2AVI to frameserve and rencode to DVD at a bitrate of around 3800. the resulting file was around 4GB. can i now burn this as a DVD-Video so that it plays like a standard DVD, which program can be used to do this?
    cheers ppl
  2. Member Treebeard's Avatar
    Aug 2002
    http://www.vcdhelp.com/author
    scroll down for different authoring guides using different software
  3. Gettin software is not a problem, so which would u recommend to burn an MPEG-2 to a dvd, freeware or commercial, DVD Maestro? or Ulead Movie Fact?
    cheers
  4. Member Treebeard's Avatar
    Aug 2002
    i've heard good things about dvd maestro.
    here is a easy dvd 2 dvdr guide that uses maestro.
    http://www.digital-forums.com/dvd2dvdr/intro.htm
  5. Member Nolonemo's Avatar
    Los Angeles
    Maestro's great, but may have more power than you need, and it's tougher to use (you have to create your own buttons, etc)
    I'm a fan of DVD Workshop, very easy to use, lots of button, meny options, templates, flexible, gives good results, authors without reencoding. About the only thing important things it can't do that Maestro can do are deal with multiple audio tracks or subtitle tracks.
  6. Originally Posted by Nolonemo
    can you import DD 5.1 audio tracks in DVD Workshop? I dont think so... so it's useless? Can you import chapters/subtitles? well I dont know anything about that software...
    who really wants make own menus in dvd-r's when you can use original menus instead... I know it's hard to learn but not too hard... 8)
    or just skip menus and only author with DVDmaestro... that's very simple to do...
    Zzzzzzzzzzz
  7. Originally Posted by Adder_78
    Yes you can as long as its muxed with the mpeg video.
    Not everyone who creates DVD's does so from ripped movies. I make motion menu's for DVD's I create from home video footage from my DV camera, and from shows I capture off the TV. Where do I get the original menu's for these ?
