I am new to Digital Video. I have had problems at times with capturing, editing and burning either VCD or DVD.
I just made one of each with some video clips, but the video quality is terrible when viewed on my TV. The video plays fine but shows significant rectangular sections. Like pieces to a puzzle. Some scenes are better or worse than others.
The original video as viewed from the camcorder on the TV is great.
What am I doing wrong. or what should I expect?
Thanks,
MjBart
Leawood, KS -
This is probably due to the low bitrate of a VCD. Try encoding using VBR and see if that helps. Sometimes, Constant Bitrate will puzzle up your video (macroblockage) for a few seconds if the bitrate is too low for that scene.
Hope That Helps!!!
:P
If you are already using standrad VCD format, then you have to go to the SVCD, which has high bit rate, twice the resoltuion ( but still restricted by your camcorder ) and only 40 minutes per CD.
Most home video, after editing can be compiled into 30 minutes. ( Unless there is a lot of flower girls in the wedding ).
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 02:06 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
video quality to movie quality
By pitta1990 in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2007, 00:31
