  1. i know this is possible, but does anyone know how i can import custom buttons (or what would be good to make them psd files??) into dvd maestro. i tried a few things but no matter what i do it takes whatever pic/file and resiszes it to fit the whole menu screen
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you make the whole menu in photoshop or even in powerpoint works ... the custom buttons are done there..
    May 2001
    One thing I do with the menus and subpictures that I create, is to put single pixel dots at the corners (ie, [0,0], [720,0], [0,480], 720,480]). That way, my media imports are always 720x480 and don't get scaled or placed other that where I want them to go.
    I had a problem with my subpictures not ending up in the proper place without this trick (and they NEED to be underneath the buttons, to work properly).
