After encoding my videos i burn them on dvd disk's but i get a lot of audio dropouts and some pixalated video! The video's play fine from the hard drive without any problems.....I am not putting to much on the disk but want to know if the media itself will cause this problem?I have used disk's from compusa,rima and some cheap media(.90) from a pc show..i use a cendyne dvd burner,thanks
I have a cendyne and have not had problems.
If it plays fine on the PC and does not exceed DVD specs then your problem is most likley with the media you are using. Cheap DVD media many times have problems that are not specific but include dropouts, problems with high bitrates, problems writing past 3.5gb, and others. -
It could also be that you burned your file at a high speed, your file contains a low bitrate, you have cheapy media, or the framerate of your source file is not 23.976fps, 25fps, or 29.97fps.
DV pixel block help
By cg_society in forum EditingReplies: 3Last Post: 26th Oct 2011, 10:42 -
Pixel format was not specified and cannot be detected
By videoBandit in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 16:45 -
pixel aspect ratio?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Aug 2009, 14:53 -
Bad Pixel. What comes next?
By videobread in forum ComputerReplies: 5Last Post: 8th Mar 2008, 22:07 -
Why would the bits/pixel drop?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 8th May 2007, 04:55
