    May 2002
    London UK
    I often download mpeg files only to find that they contain errors, perhaps one or many corrupted frames.
    Is there a program/utility that will scan through an mpeg file and report the position of any corrupted frames (much the same as DivFix does for .avi files)?
    If I knew the position of the errors I could then chop the file just before the corrupt section, and restart the download from that point, rather than having to download the whole file again.
    Thanks for your advice
  2. Try VCDGEAR...
    Set it for Mpeg > Mpeg and check the "fix mpeg" box.
    http://www.vcdgear.com/download.html
    "Today is only yesterdays tomorrow"
  3. Or maybe MPEG Corrector found here under:
    Tools > Repair..
    http://www.vcdhelp.com/tools
