If I start with an AVI captured from my digital camcorder with audio initially recorded as 16 bit PCM (48,000 Hz) and I use TMPGEnc to generate separate video (.m2v) and audio (.wav) files, with the audio settings in TMPGEnc set to PCM (48,000 Hz), is any re-encoding of the audio going on within TMPGEnc, or is it just separating out the audio portion of the AVI and putting it in a .wav file?
More generally, is there any better way to produce the input I need for authoring via MyDVD (which requires PCM audio).
Any insight would be appreciated.
Regards,
Eric J
Results 1 to 1 of 1
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 16:46 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
PCM WAV file bitrate too high?
By djdust in forum AudioReplies: 1Last Post: 19th Feb 2008, 16:05 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
