ok i downloaded files off kazaa and i am burning them to a dvd is their anyway to make it so my dvd player is able to fast forward them? also i only used tmpgenc like 3 times and it says my time is up is there anyway to get another trial version?
No Warez Disscussion
TGPO
Anyway, I was having problems FF+RR as well & came across your post. Any luck? I added scandata.dat to the EXT folder, but, no luck. All I can do is pause.
Email me if you figure it out.
Fast forwarding and rewinding a tape before capture?
By justin81 in forum RestorationReplies: 4Last Post: 14th May 2010, 16:41 -
Video freezing when fast-forwarding.
By xcodyj in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 03:45 -
Viewing during VCR fast forwarding/rewinding
By spinmonk in forum Capturing and VCRReplies: 12Last Post: 30th Aug 2009, 18:30 -
ogm's fast forwarding
By CommanderZero in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 23:23 -
fast forwarding flvs with vlc?
By majax79 in forum Software PlayingReplies: 2Last Post: 20th Sep 2007, 13:54
