Hi!
I'm using WinDVR2 to capture TV to SVCD. I noticed WinDVR splits the file every 592 MB and starts a new one. Why is that and how do I stop it?![]()
I don't want to merge them back into one piece after recording![]()
Any help would be great![]()
Thanks, CU Primal
You can set the file size to have "burn-ready" files without needing to split after capturing. :P
How do you set the file size? I just tried recording a movie using custom sertting for VCD file. The first hour worked out just fine, but the second file won't load in TMPGEnc. I think it reverted back to some other format.
Thanks.
Oh, I figured it out. Make a DUPLICATE of the custimized quality settings and you can adjust file size, etc.
MP4Box & splitting -- won't do as told
By Virnec in forum LinuxReplies: 2Last Post: 23rd Feb 2012, 10:19 -
Splitting a .TS file in half
By danielmak in forum MacReplies: 4Last Post: 1st May 2011, 01:19 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44 -
Splitting & fading
By carlmart in forum AudioReplies: 32Last Post: 5th Oct 2009, 18:34 -
Splitting avi file
By tryst1 in forum EditingReplies: 2Last Post: 15th Nov 2007, 04:33
