Ok I select iso/udf in Nero, input my VIDEO_TS and AUDIO_TS folders and it burns ok and works perfect in pc and standalone.
I select iso/udf in Gear Pro 6.02, input my VIDEO_TS and AUDIO_TS folders and it burns ok and works perfect in pc and standalone.
I do the same in Primo (in disc mode), it gives me no errors, burns the disc fine, but won't play in anything, even pc.
This is using the same media and same folders from my hdd.
Any ideas why this should be???, Its really bugging me, as I thought this was the prog to have for dvd. Its also the same for Record Max Now,(which is the same prog as Primo) so its got to be something to do with the settings.
The folders must be compliant otherwise Primo usually tells you there's an error, and the other progs burn 'em fine
I've run the px engine, and dvd settings in Primo are set to ;
Disc at Once (dao)
UDF with Joliet- up to 106 in length, any character,plus joliet,plus 8+3 tree (bridge)
cheers
Raider
makesure in recordnow, under the options tab, then Data, that the recognize VIDEO_TS AUDIO_TS per DVD specifications box is check. Might help out. If this box is not checked the data will burn fine, though the dvd will not play in anything.
yep,all those settings are ok then, and yes I've got that ticked Wetmonkey, but still no go. Trouble is, that the disc burns fine, same as it does in all the other progs, but it won't play when burnt in Primo
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
