I've been using my nero program to burn .cue files but how do I burn .bin files.
Go download BlindWrite suite and use that to burn your bin files. It's reall easy to use.
.cue files contain no data at all whatspever. They're cue sheets for the .bin files. (Just open your .cue with notepad and you'll see what's in it) Anyways, I always by good measure open the .cue in notepad, for the path is wrong (very often). Then into nero, go file, burn CD image, select your .cue, and that will burn your .bin file... Hope that helps
Ok I go to Nero and open the .cue files and it showing that there is 646 mb to burn which is good but now i get this error from nero:
Cannot write compliation in TAO with this recorder
THIS IS THE ERROR I GET From my nero log.
Recorder: <LG CD-RW CED-8120B> Version: 1.09 - HA 1 TA 1 - 5.5.7.8
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI
CD-ROM: <Compaq DVD-ROM DVD-116>Version: 1.06 - HA 1 TA 0 - 5.5.7.8
=== Scsi-Device-Map ===
DiskPeripheral : ST340823A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : Compaq DVD-ROM DVD-116 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LG CD-RW CED-8120B atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 639MB (654896kB)
Free physical memory: 377MB (386172kB)
Memory in use : 41 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
CueSheet
5.12.2002
10:40:07 AM #1 Text 0 File Reader.cpp, Line 118
Reader running
10:40:07 AM #2 Text 0 File Burncd.cpp, Line 2621
Turn on Track-At-Once, using CD-R/RW media
10:40:07 AM #3 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (original item values)
0: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
2 indices, index0 (150) provided
original CD pos #0 + 450 (450) = #450/0:6.0
relocatable, CD pos for caching/writing not required/not required, no patch infos
1: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
2 indices, index0 (0) provided
original CD pos #0 + 286128 (286128) = #286128/63:35.3
10:40:23 AM #4 Phase 40 File dlgbrnst.cpp, Line 1438
Aborted by user
10:40:23 AM #5 Text 0 File DlgWaitCD.cpp, Line 196
Disc check failed: Initializing Disc Info
10:40:23 AM #6 SCSI -1080 File Cdrdrv.cpp, Line 1211
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x0012E5D8
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x3A
Sense Qual: 0x02
CDB Data: 0x51 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x22 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x3A 0x02
10:40:23 AM #7 Text 0 File DlgWaitCD.cpp, Line 1338
Recorder: LG CD-RW CED-8120B;
CD type reading failed
ATIP Data: ?
10:40:23 AM #8 Text 0 File Scsicmd.cpp, Line 368
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 10/29/2002 9:08:46 PM
File 'Drivers\CDRALW2K.SYS': Ver=5.3.2.34, size=23420 bytes, created 10/26/2002 8:02:57 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001) built by: WinDDK, size=16512 bytes, created 5/6/2002 11:01:14 AM
File 'WNASPINT.DLL': Ver=V1.17, size=55808 bytes, created 9/19/2002 12:00:00 AM
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
