which software can resize the font in sub that i can see a larger sub's in my finale movie?
That depends on what format your subs are in, in the first place. If they are in .SSA, you can specify which font (and size) to use. What happens next depends on in which format you want for your final movie. If you're using VirtualDub, then use Gabest TextSub filter to add the subs. For creating (S)VCD, then frameserve to your fav MPEG encoder.
/Mats -
im not clearly about waht you said.. i have ssa format and i want to put the resize sub on mpeg2 file (after frameserve with virtualdub)
What you need to do then is download 'Sub Station Alpha'
the program that produces .SSA format subs and then load your
.SSA file into it.
Then you can change the font size the colour and allsorts of other
goodies.Save your subs as a new .SSA file and then frameserve
from Avisynth to your mpeg encoder.
I'll post the script that can do this later...i'm still at work!
Waylander -
i did that and i got wrong font and smaller size of the font in the finale ssa!!
weird -
No need to use SubstationAlpha, as you can edit the ssa with Notepad:
As you can see, the SSA has comments that tells you what field does what.[V4 Styles]
Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold, Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
Style: Foo,MS Gothic,72,65535,65280,65535,0,0,-1,1,2,4,2,30,30,30,0,128
Now, every time you use foo as Style for a text, it will be in MS Gothic 72pt.
/Mats
PS! If I had to choose just one app to use for the rest of my life, I'd choose Notepad any day. DS
Best subtitle font?
By flickerx in forum SubtitleReplies: 21Last Post: 14th Feb 2019, 17:36 -
What subtitle font is this?
By jonghyunchung in forum SubtitleReplies: 6Last Post: 16th Feb 2010, 16:59 -
Serious font problem in my PC
By alegator in forum ComputerReplies: 8Last Post: 3rd Nov 2008, 07:59 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Which font looks like.....
By mol3000 in forum ComputerReplies: 13Last Post: 4th Jan 2008, 15:03
