ok i have a Tosiba 1502(16x dvdrom) and the darn thing only rips at 2X in DVDdecrypterbut my old creative 6x dvdrom rips AT 6x
in DVDdecrypter what gives?
My roomate has the same drive and the same problem. If anyone knows of a fix or what is possibly wrong please let me know.
thanks in advance,
Buck
Results 1 to 11 of 11
Some new models of dvd-rom's are locked to 2x ripping speed!Originally Posted by Buckshot
Many DVD-+R(W)'s are locked to 2X ripping speed!
Zzzzzzzzzz -
because movie industry dont like that you rip dvd's...Originally Posted by miketree
Zzzzzzzzzzz -
Check to make sure you're DVD is in DMA mode and not PIO - Control Panel then System then Hardware then Controller settings (check other posts for better instructions if you can't find this setting).
If your DVD is in PIO even when you have Use DMA if available it may be a DVD firmware problem - check you manufacturers site to get an updated firmware (or you may have to do a little hunting through the web) - follow the instructions for upgrading firmware carefully!
I use a Pioneer 115 for ripping and I was having the same problem as you - ripping was only 1.2X at best. PIO was all I could get... Upgraded the firmware, DMA "turned on" and I'm now ripping up to 10X. -
What exactly is DMA. I am not having any problems, but I checked my settings and my DVD-rom has DMA checked, but my CD-RW does not. Should I just check it on? Is DMA good to have?
yes its good... if you cd-rw support dma...(almost all support dma)Originally Posted by DivXExpert
Zzzzzzzzzzzz -
DMA = Direct Memory Access. Basically a means in which data can be read bypassing much of your systems overhead.
PIO = Processor Input/Output. Slower but I would imagine less problematic.
When available you should always use DMA - if you find errors/crashes cropping up then you may have to revert back to PIO. -
Yes DMA is enabled and the drive comes up as Ultra DMA Mode 2 so im not sure what the trouble is. the drive is atleast a year and a half old and so is my roommates. all i know is this sucks being locked at 2x
thanks for your responses. and keep the ideas coming if you have any.
Buck -
Well, why just limit it to 2x rather than stop it?Originally Posted by Adder_78
that would be DVD-ROM -> CD-ROMOriginally Posted by miketree
http://cd-rw.org/news/archive/3537.cfm :
"-- virtually all new DVD drives, manufactured in 2002, are capped so that the DVD ripping can be done only at max 2x speed. Thanks to MPAA."
maybe MPAA knows why new DVD-ROM's/DVD-RW's are locked... 8)
Zzzzzzzzzzzzzz
Movie speeds
By drmrsolds in forum Video ConversionReplies: 8Last Post: 16th Nov 2009, 07:35 -
Write Speeds - anything new?
By Mike99 in forum MediaReplies: 22Last Post: 10th Feb 2009, 20:41 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 08:28 -
Encoding speeds
By Illusionist in forum ComputerReplies: 13Last Post: 11th Jul 2008, 11:01 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11
