i want tp author an mpeg2 file 3GB file
i used DVDit 2.5 PE everything was good untill i gave him "build DVD folder" i chose a path to my biggest HD 80GB and he pop up a window that say i do not have enough space!!
why?
How much space do you have left on the 80gig drive? I found that DVDit needs at least double the space to create the DVD folder(8-10gig for a 4.7gig DVD). Also you might want to check to see how big the DVD will be by checking the video section under the build menu.
i figure it out its ok...my temp dir was on 2GB space...
i have other problem:
i build a simple menu picture with PLAY on it
after burning when trying to play the movie on my stand alone dvd
it give me black screen insted of the main menu!
but when i play it in my DVD-ROM on my pc it shows the menu !!
why?
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 14:53 -
Help with Strange Problem?
By Mitchum22 in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2010, 22:10 -
Strange PSU problem
By mysts in forum ComputerReplies: 9Last Post: 20th Jun 2009, 12:12 -
Strange Problem with MP4Box
By belatu in forum Video ConversionReplies: 4Last Post: 18th Jun 2009, 10:09 -
Strange AGP Problem ???
By blinky88 in forum ComputerReplies: 21Last Post: 14th Jun 2009, 11:47
