I was in a hurry and didn't change the framerate from the default 29.97 to 25 with ffmpegX. In previous builds, this would have merely created more frames, but in current versions, it changes the time. Odd thing is that it created a file much smaller than a virtually identical file where I entered the framerate correctly.
The .mov I made by adding scaled in QT Pro is fine and in perfect synch, but I would like to rescue the .avi. I want to interleave the files using ffmpeg's passthrough feature.
I seem to recall -- but couldn't find it on Google no matter how I searched -- that one could change the timecode of an .avi with HexEdit. Can anyone give me any info. on this?
Results 1 to 1 of 1
Repairing/Fixing .mov ideas or help with hexedit
By Jabus in forum RestorationReplies: 7Last Post: 9th Jun 2010, 20:53 -
timecode effect - change color/background how
By The Linguist in forum EditingReplies: 7Last Post: 16th Jan 2010, 20:10 -
HexEdit DVD Player Firmware -- "REPLACE CHKSUM"??
By dursman in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2009, 09:55 -
Split xvid/avi at x MB instead of x frames/timecode
By Xavier in forum EditingReplies: 4Last Post: 3rd Mar 2009, 16:51 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22
