Everytime i try encode an avi with TMPGEnc the result has no audio. i have tried updating my version but it hasnt helped, is there any plugin's i need for the audio to work or am i doing something wrong?
PLEASE HELP!
Thanks![]()
email at --> hunka_man@hotmail.com
have you tried convert the audio to wav and then convert it?
www.vcdhelp.com/virtualdubaudio
www.vcdhelp.com/tmpgenc#problems -
Hmmmmm yeah i have tried it before by following the instructions on the vcdhelp site but i will try again and see what happens.
If it doesnt work what else can i do?? -
This may be too elementary so sorry if this does not help.
1) Are you sure the *.AVi file you are encoding has a good audio track. If you captured without the LINE IN selected for you recording sound settings then you will hear the sound while capture but you will not be capturing the sound for real.
2) If the item 1 is not the problem maybe try stripping out the audio to a *.wav and see if that plays OK. Use a tool that will allow you to strip out the audio from a *.AVI I just don't know what tool does this. Maybe the sound track is messed up before encoding and its not the encoding.
Just a thought -
After converting a .mov quicktime to mpeg1 in TMPGenc which worked fine , I converted that to mpeg2 , and that file had no sound either . With that I just remultiplexed it with the mpeg2 video , added the mpeg1 file and deleted out the mpeg1 video off the list - then multiplexed it (within TMPGenc), which worked , I still don`t know why it didn`t work straight away though .
You could as a work-around click on audio only (on stream type)then load the avi file - then in the first menu , select "Output To File" and select Wave from the submenu , then save it . Then code the file using the wav file as your source for audio , if that doesn`t work then rip the wave out with Virtualdub and use that (like hardwork12 suggested).
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 20:52 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 10:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 06:27 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41
