not virtualDub
i want to rip the wav from Xivd....
not sure if I understand the question - or if it is one question or two?
A lot of sound editors can open avi files & extract the audio - I know SoundForge can, I think GoldWave can, and I suspect CoolEdit can.
I'm not so sure about different codecs though - xvid and ac3 etc...
' hope that's of some help!
cheers,
mcdruid. -
You can use TMPGEnc
File, output to file, wave file.
By the way, whats wrong with virtualdub -
sync problem with virtualdub...
so tmpgenc can rip to wav from Avi file and also from mpeg2 file? -
When you say sync problem do you mean when you encode. Are you trying to save a VBR audio stream as an uncompressed PCM wav file. If so make sure you set the audio to full processing mode and not direct stream copy.
How to rip dvd audio to mp3 or wav files?
By babypotato in forum DVD RippingReplies: 12Last Post: 17th Jul 2011, 04:22 -
Wav channel splitter software wanted
By joejack11 in forum AudioReplies: 3Last Post: 7th Nov 2010, 12:12 -
Convert MP3 -> WAV, Copy to HD and RIP
By ctdvd in forum AudioReplies: 4Last Post: 23rd Jan 2010, 07:32 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 05:13 -
rip DVD music to Wav
By fabioacer in forum DVD RippingReplies: 6Last Post: 19th Jun 2007, 15:37
